It would be fun to try, but on an unfinished wood surface the misting would probably make the wood fibers swell and warp the wood before it gets lasered. I wonder if the heat and drying effect of the laser would flatten it?
Good feature for the hopper! (cc @Tony) But no, right now you would need to experiment to see what depth you’d reach.
Fully functional? Depends on what Data you input…
Everything you said holds true for plastic sheet (like Delrin) and potentially metal (aluminum / steel)…unless it was Blanchard ground after stress relieving like Mic6 is (I believe).
I know one machine shop who will go back-and-forth from front-to-back upwards of seven times in order to machine something flat out of Delrin, and another shop who will machine it to rough size, send it out to be annealed, and then finish machine it too size. Internal stresses are nothing to take lightly
