As @ca_worth stated, I recommend you use veg tanned.
It is absolutely gorgeous. LOVE IT!
I do like the stitching on the outside.
Excellent work. I may have missed an earlier post, but can you share what you use for stitching, stitch spacing, etc. I’m making a carrying bag for one of my game boards and want to give this a try. Thoughts?
Thank you.
Great question. The spacing is based on the leather tool called a diamond hole chisel which alternate in spacing from 2mm to 5mm and so on. In lieu of using the diamond shape, I used a round shape. Good luck and feel free to share the bag with me when it’s done!
Tim,
Thanks for that info. What do you use for stitching … leather strips???
Dave
so any typos are due
to large fingers & small keys.
Dave, I use waxed thread for stitching. This is a standard in the leatherworking industry because it allows you to stitch your products without fraying the thread as you get further through your stitching. You can use leather strips as well. It all depends on your design and the aesthetic. Good luck
how much of the “char” from burning the holes does your thread pick up? did you have a way to clean that out before you started the stitching? i’ve only tried one leather piece so far, but i’m glad i used black thread so you couldn’t see any discoloring from that.
Excellent.
Great question. I tested this using a red waxed thread for a different project that you can see in this post: iPad Pro 9.7 Inch Sleeve Prototype
The thread picks up some of the char and it really depends on the ounce of the leather and your power/speed settings. The thicker the leather, the more time and power it takes to cut (also more passes), which leaves more charring. It also depends on how you’re stitching (i.e. does your thread move around much as it passes through? If so, there may be more char on the thread. This is a minor note that has relatively little impact).
I’ll also be testing another method of making soon to avoid the char getting onto the thread. Hope this helps!
thanks, that does a bit. i was cutting some saddleback full grain leather from a scrap bag, so it was very thick and that probably affected how much char. was hoping there was a magic “do this and it will help clean some of that out first” method out there, so i’m looking forward to hearing about the method you’re testing.
Solid project.
#necrogame
What power/speed settings do you suggest?
