Loses power/results change same material/same settings
I’ve frequently had trouble with leather that isn’t Proofgrade (which tends to be kind of thin). Other tanners don’t seem to always have uniform thickness on the leather scraping, even on the same piece.
Don’t know what to suggest other than what you’ve already discovered…get it as flat as you can, pin it down everywhere with the Honeycomb Pins and be prepared to run a second pass, or use a slower cutting speed.
