Making Stamps with Inventables Linoleum
It came out great!
One thing to keep in mind when designing stamps is that you will get better stamping results if you taper the engraving away from the top surface so the base is wider than the stamping surface. It is especially important for fine details, which have a tendency to wiggle when you stamp them due to lack of support.
I put together a quickie guide for doing this (created for clear stamp polymer but the principles are the same):
