The contact cement I use for leather is absolutely vicious. It touches, it’s adhered. I’ll have to play around with 77 sometime.
Colors are fantastic. Really great piece.
FWIW, i use the 77 for puzzles. that’s a far more stringent load than the mandala, since there’s a lot more handling. spray both the back of the print and the board.
Just curious: what happens if you paint the DB? Also what to you us to mask the painted wood for cutting?
I assume you mean draftboard? I’m using Baltic birch plywood. There are other threads about painting draftboard if you hunt around on the forum.
As for using paint in this sort of thing, see my other mandala threads, I get into it there.
https://community.glowforge.com/search?q=%40evansd2%20in%3Afirst%20mandala%20order%3Alatest_topic
I mask using the same stuff I always do:
Thanks for the info!
