Manuel settings
Is this plywood? If you search, you’ll probably also find some starting places, but keep in mind that wood/ply can vary a lot, so a setting is a starting place. You’ll likely have to tweak them to get optimal settings.
Here’s the first result from a search on “1/4 birch”
