Painters Tape and 3M Tape Sheet
here we go:
Blue tape does work, but it’s a pain to get the strips lined up, and it’s tackier than you probably would like. Take baltic birch for example: Blue tape will pull up wood fibers and mess up your surface. Medium tack transfer tape? Not a problem.
Need it to stick bit more? sand your material a bit smoother. The smoother your surface is, the more your masking will adhere. I like to leave my surface juuust a bit rough (like 120/220 grit smooth) so that the masking comes right off.
The irony here is that I use 3" wide blue tape to pull my masking off of large numbers of small parts. :slight_smile: It works because the blue tape is stickier than the masking, so when you pull the blue tape off, it takes the masking off of the material (wood in most cases). I call it my “tape sandwich” method. (search for that, and you’ll see I discussed previously)
@jbmanning5 has a “double cut” method, which I’ll let him discuss if he likes. It’s clever, but described elsewhere.
