Huurah! this will make some projects possible for me that just wouldn’t be otherwise.
So, just as a proof of concept, I took this file and changed the outline to a different color, so it would cut out last. Used some magnets to hold down all four corners. Max speed power 1 for the score lines, power 25 for the cut. I didn’t mess around with focus height this time, just kept everything at minimum 0.010".
There were some burn through at corners and you can see the crease lines. Cut separated cleanly. Paper folds at the creases, but not easily. Going through and prefolding all the creases definitely helps.
In the end, I was able to coerce the thing to make a not entirely impressive swan:
So yes, it kind of works, sort of, but unless the power can be ramped on cuts/scores to match the head acceleration/deceleration more precisely, you will see pinholes at corners. I think messing around with higher power/slower speed/defocusing might have improved results.
Yeah, they changed the power profile a couple of months ago giving us the ability to work on paper very nicely now.
(Can’t wait to see your Pepakura. )
By the way Jin, you have the option of converting the $100 credit that you earned from my order into $125 in Proofgrade credits if you choose…you might want to take it. The stuff is fantastic. Wasn’t sure if you had seen that yet.
(You don’t get it until I get my machine though. They want to make sure I don’t cancel.)
Even the lowest power setting burns through at corners. I think it’s because the printhead has to decelerate for turns, putting in more energy at the ends of runs than in the middle when it’s up to speed. When working at the lowest power setting, there is not any more room below to ramp down the power for the slower speed. One possible solution would be to start and stop scoring runs before and after the actual segment, taking the kind of path that craft cutters with swiveling blades do to realign the blade for the next direction of cut. I don’t think there’s any way to command that kind of thing from a design, however (introducing a portion of a cut/score with different power). Any independent path segments will be cut in a random order. Maybe someday GF can be persuaded to implement that sort of thing.
Yeah, I’m worried about that, too.
I have tried manually editing files in design software to stop score lines just short of intersections or corners, and it does remove the burn-through at the corner but you also get a tiny hot spot at any point where the laser starts/stops firing.
I believe that a power ramping feature for corners is in the plans for the Glowforge software but we don’t know an ETA.
If I’m doing my own designs I just remove the corners. (Round them a bit.) It provides a transition instead of a point where the laser pauses to make a turn.
If you want to be certain of no extra burn on corners, you can run as engrave. But that means the job will take quite a bit longer. Curious if the lowest LPI would be sufficient.
I know all materials are a bit different, but I had to use 10 power at full speed cut on my machine to get through a cue card, and just barely. Is printer paper that much thinner and easier to burn?
No, I don’t think so, I use full speed, 20 power for a full cut on paper. But, during a score run, the head will come to a complete stop when changing directions briefly, dumping a lot of energy even at min power. Plus, where there is a situation where multiple lines cross at the same point, the crossing point will have the contribution of all the lines.
I don’t think any power ramping will help in this situation because it’s already using the minimal power, and there is presumably no way to go even lower.
My suggestion was not only to turn off before the actual corner, but to traverse the entire score segment at full speed, starting before laser on and stopping after laser off, so that the head is already traveling at full speed for the full length. Kind of like an engrave pass, but on the vector path.
Hopefully @glowforge will build some sort of backend code that will look for intersecting points and only laser it once, and maybe corner compensation.
Like this: Prototyping with Corrugated Cardboard
I know it’s been discussed and suggested multiple times, so here’s hoping
I know I’m hoping to work with paper some, but burn through in the corners wouldn’t be acceptable for what I want to do.
Yes! Exactly. And as long as we’re wishing for ponies, maybe some way to specify a way to shut off the laser just as it’s coming up to an intersection with another score line to prevent overburn on crossing scores.
I would welcome an “avoid intersection doublecuts” check-button in the manual score dialog box.
