fantastic! thank you so much for sharing your settings - and print time!
Isn’t the Baltic Birch ply amazing?! I am using it for the back of my Wall Art Tiles now. I am super fortunate enough to live 15 miles from Cherokee Wood, so when I ran out of PG Draftboard and needed a local fast substitute I found those guys.
I seem to be asking so many questions these days… When using denatured alcohol to clean, are you mostly just wetting a scrub brush and rubbing it, or a cloth, or is there more to it? I’m assuming its a brush just to mitigate the mess?
Also, am I wrong in assuming that Methyl Hydrate will work just as well? DNA is hard to find in Canada now for some reason, but this seems to be about the same thing…
@forhorsman I pour DNA into a large tray and soak the engraved birch ply in it for a few minutes. Then, I work a soft brush over the piece. I remove it and dry with a microfiber cloth. Repeat if necessary until the desired look is achieved.
Methyl hydrate is also known as methanol. Since DNA is a mixture of methanol and ethanol, I don’t see why using straight methanol would be an issue.
