here is the edited svg in case it helps anyone else.
I did not double check the colors for engrave/cut order…
- set the cuts to ignore, engrave oval - I went with full power, 1000 speed, 340 lpi - med maple cut about .075 depth
- set oval to ignore and run the cuts. the outline at med poplar cut fine, the keyhole 1 ran 2x at 500 speed, full power, focus set to 0.05 (we engraved .075 of the .125 PG thickness off)
I’m sure engrave time could be shortened if we engrave only the difference between keyhole and the oval…
