and that is why you practice practice practice.
what my dad turns and sells now is simply not on the same planet as what he first made.
I resemble that remark. ![]()
Hi Shogun, where did you get your rubber tips for your lathe?
Inspiring!! Very well done and gives me such ideas!!
Thanks so much for sharing!
I turned the sphere holders out of HDPE cylinders I got off of ebay. I had a few I made out of wood, but I ended up with a lot of friction burns. I am not seeing the cylinders I used for sale right now, but I would bet something like this would work:
(6) 1.91" DR11 HDPE Mortar Tube. Orange DR11 HDPE. 11 7/8" length.
One thing to note if you decide to turn your own out of hdpe: The material tends to come off in a single long, thin strip, which is then whipped around by the lathe. This will either flog you or wrap around the chuck. It’s kind of annoying, but manageable.
If you watch the video that @evansd2 posted the one human is eyeballing with a finished piece laying behind. But if you have a profile drawn, you can set it up in line behind the piece. Then as you take material off you can look “through” your spinning work to use the profile as a guide. If the profile is cut out of say plywood or acrylic you can set it down along your piece to test your progress.
These would be great for custom bocce balls.
