Very clean, professional product.
Wow. That is awesome!
So awesome. How many sheets of acrylic did that take?
I bet this would look really neat if you used some glow in the dark acrylic as well. like do a spot pattern on the petals and then after you shut it off you get a nice glow that fades out.
There is such a thing as glow in the dark acrylic? Sounds awesome.
Rowmark LaserGlow
Thanks. I like the concept.
Yar seen it on inventables yrs ago. i think the dual layer black front stuff would look the best. Have not used it myself but its on the list of things to try. Also not sure if the acrylic itself is “glow in the dark” or if it is a surface coating.
Sweet. I have to get some of that.
2 full sheets of 12”x24”, and had to use passthrough to be able to cut edge to edge.
I assume the same amount for the wood?
Well, I used Proofgrade so it was 12”x20” sheets, but was able to nest the smaller leafs into the bigger leafs, but then a couple extra sheets for the vertical struts & hubs.
I must follow you on Instagram as I know I just liked these recently there! Just stunning!
Thank you, to one on my 10’s of followers!
The hanging color makes it fun. Very cool lamp!
THIS IS SO STUNNING!!! I thought it deserved all caps
Wow!!
