When I put together the chip vacuum for my X-Carve I got conductive vacuum hose, which has ground wire built in, then the dust separator is also conductive. Wasn’t super expensive to get it all to be static conducting.
Does Flanders still make these?
I didn’t see an answer to this so here is my tale.
I made a ~ 9x11.5 box with 1/8 inch offset holes (actual holes were probably ~.05 inches). I glued aluminum foil on top and used a needle to open the holes. At first I planned to use my jump battery and some exhaust fan, but what I had with sufficient power did not fit in the 2 inch space. Instead, I ended up opening the flop down door and fitting a taped foam door with a plastic tube going to the box. I used a vacuum sweeper in the room, getting a hint of smell, but not much. I needed two magnets to defeat the safety switch. I don’t think there is very much air penetrating the paper so I don’t believe the cooling is much affected. Now if I had design skills like the rest of you, I’d be in business but I did keep my paper from blowing when I cut it.
the filter { bought to not need a window has not worked out as the intake is ten inches diameter but at 500 CFM it could pull a lot of vacuum and deal with the smoke etc at the same time but still need a conversion from passthrough slot to the ten inch opening.
Easier I think is to have a Stainless or Aluminium plate with adhesive.
This sounds like NASA telling Apollo 13 how to make a CO2 scrubber. LOL
