And then go buy more shelves ![]()
Rinse, repeat. I know.
I purchased some cut down sheets from them recently. Do you know if the paper/plastic coating is safe to laser? Iāve attached a picture of it. Also, is the brand you get from them called āChemcastā?
Iāve never had problems with the paper, but I generally remove it before engraving.
As far as I know, chemcast supplies Glowforge with their colored acrylic. I use chemcast all the time.
Great. Thank you for the reply.
Iāve gotten some of that stuff from TAP Plastics. I laser it with the covering on, and the Proofgrade settings for the closest color work great so far!
Thank you.
What everyone else said. But if itās got a plastic masking then remove it 100% of the time (paper I remove for engraves Iām not going to paint or where Iād be weeding forever due to the detail). Plastic masking just melts and globs up.
As pictured above, it is paper with a thin layer of plastic under it. I actually had problems engraving with the protection paper removed. It seemed the laser vaporized the acrylic and left a very hard-to-remove film on the surface, around the recessed engrave, some that I could not remove. When I ran the design with the film, everything was fine (though it is not as easy to pull off as the PG masking). Do you not get a hazy film on the surface of the acrylic from the smoke/dust that is difficult to remove? Thank you for the feedback.
Iām not sure itās plastic - I use it all the time (I donāt find a lot of difference using PG Acrylic vs Chemcast or other cast acrylic so I go with whatās available locally and/or cheapest
). I think thatās a glue layer - it does seem to be a film all by itself though when you peel it back.
Yep and especially noticeable as a ghosting on clear or a white shadow on black. Thatās why I keep the paper on for my acrylic engraves. I know a lot of people always take it off, but Iād rather weed a bit than have to work at removing the haze - I find that requires something like Novus polish and thatās just more work.
Gotcha. Thanks again for the reply. Iām with you on keeping the paper on when engraving.
Same here - I leave the paper on to cut/engrave, because unmasked leaves a dusting of vaporized material that doesnāt look good and is hard to clean off. Weeding is harder than PG, but the variety of materials is amazing, as is the price. The only downsides are that you have to order 4x8 sheets, and it takes a week or two to get the material shipped between warehouses (unless they stock it locally), and then cut. So you have to plan in advance.
It really is nice talking with people who know the materials, layering, etc.
Wish I could find a place locally like this for wood!
