Posting this in everything else since it was not done on a Glowforge, but hey, it does use Proofgrade materials and like to share my projects! Since I have multiple lasers in my shop, I thought I’d post a few comments on this project using the Mira 9 compared to using my Glowforge in case anyone is interested.
This is the first map I’ve done on the Mira 9, and hope to make a 24"x36" layered map someday. One positive is being able to maximize material. I do have a lot of 12"x20" sheets. Normally my Glowforge-made maps were limited to a height of ~10.86" with the design flipped landscape, assuming I didn’t want to use pro pass through. With the Mira 9’s larger bed, I’m able to stretch the width of this map to 11.6", so almost edge to edge on a piece of proofgrade. You could go bigger if you created a jig, but I didn’t want to monkey around trying to get closer to 12". The middle layers were painted 1/16" mdf, but the top layer, bottom layer, and frame were plywood. The Mira 9 is also quite a bit faster than the
, but I’m never really in a big hurry.
I’m always happy to answer any questions on the Mira 9, or comparisons with my other lasers!
Timelapse for instagram
