I created this design to help you make as many, as fast, and as economical as possible.
this file will cut
102 Double
7 Child
1 Extra large
from 1 sheet in about 35 minutes.
this file will cut
102 Double
7 Child
1 Extra large
Nicely done!
Thank you so much - this file cuts beautifully in 25:47 min on a Pro using Med PG Acrylic settings. (1/8" no name non PG acrylic used)
Nice nesting!
The 20x11 in the file code in your post is the display size of the image. If you tack a couple of zeros on the ends of each of those numbers, it will display in a size that people can see more easily.
Thank you
its not showing anything that i can see anyway
It’s right here:
My screen shows the same way. Use the drop-down arrow just below the post and the link for the file will appear. Opens beautifully.
thanks!
I fixed it. sorry about that.
I fixed it. Sorry about that.
No worries just didn’t know if I was missing anything lol. Ty for your contribution
WHOA, I never knew about that! Thanks for pointing it out.
Hi just purchased my glowforge. They are cut from acrylic correct. Where can I get it? What thickness etc. I would love to donate some but don’t know where to start.
Any of the medium 1/8in from glowforge
So who’s found it without cutting the file? Took me a min before it dawned on me the most logical places.
The sample pack should have a sheet of 1/8" PG acrylic.
Unfortunately, my sample pack has thick acrylic 1/4", not 1/8". THANK YOU Stay safe.
Ah, sorry about that, it’s changed since I’ve ordered.
25! Nice
