I just finished up 12 centerpieces for the SPARK Museum Gala/Auction on February 29. Each table will represent an important electrical invention or discovery, as indicated by its centerpiece. We’ll also be auctioning off the centerpieces at the end of the evening! The towers are scale models of Nikola Tesla’s Wardenclyffe Tower, built in Shoreham, NY around 1915 or so.
I designed the tower to scale in Illustrator, using an old photo as a guide. The LED bases are hidden behind a cover made from “living hinge” plywood.
These are really impressive. I am also amazed that they are completed and the event is a month away. How is it even possible to complete such great work so far in advance of the deadline?
The graphics on each are amazing on their own, but the whole thing turned out awesome. The addition of the living hinge to hide the base is really great too. Love this!!!
Thanks folks! I forgot to mention they are 16” tall, in case you were wondering. The tops attach with a magnet, for easy removal to change the batteries.
So awesome! The part I like best is that you incorporated several different build methods in one piece. Flat cut pieces assembled into 3D shapes, living hinge, 3D engraving, edge lit panels. Nice!
Thanks Andy. There are a couple of other places I used the gf that you can’t see:
cut the circle of felt that is glued to the bottom
engraved an inlay on the top of the tower that holds a magnet (the magnet attaches to to a small steel plate that is stuck to the bottom of the LED puck with double sided tape). Makes removing the top really easy to change batteries.
