After a few failed attempts, I was finally able to complete a few stamps using my Spark. They definitely take time smh. Avg 3-4hrs each. Not an item I plan on offering unfortunately.
Oh, very nice! I’m always a sucker for a well-made stamp. Maybe eventually you will decide to upgrade to a higher-powered laser. They do go a lot faster! Nice to see the Spark can do this job tho.
Very nice. I love making the stamps…as @cynd11 said, easier on a more powerful laser.
I wonder if it would be possible to laser a blank and then cast copies of a stamp?
Even with a higher power laser it’s not a practical manufacturing method.
Nicely done. Did the material stink bad when engraving?
If you are going to make them from something besides rubber anyway, you could just make photopolymer stamps. I haven’t looked into that in ages, but you should be able to get a machine designed to do that for a couple hundred USD.
I was thinking cast silicone or something. But yeah that would be cool.
I didn’t notice a bad smell but i do vent out the window. The clean up inside the machine afterwards can be a lot though.
Welcome to the forum @temikaewell. Great first post and stamps.
As I see it, failed attempts are steps of the learning curve you need to experience to aquire mastery.
Thanks for sharing, I look forward to more of your posts.
Welcome to the forum!
Nice that you had success, even if you don’t plan to make them in the future. They look good.
If “precision” isn’t a requirement and a kind of “well-used” look is acceptable, I have made one-time use stamps by simply deeply engraving scraps of draftboard/MDF. Slap on the paint and apply it - carefully. I use tape to allow me to drop it into place, press it down, then lift away cleanly.
Welcome to the forum! Your stamps look like they turned out great, even though it took so long to make them. The details show nicely.
