3d printing request
Can anyone do a ‘simple’ 3d print for me ?
A truncated cone, bottom diameter 1", top diameter 0.5", Z height 5", with a central hole 3/16" right through the length. Also with 4 grooves running up the length, equally spaced around the circumference, each being ~1/32" diameter semicircles in cross section. If it’s economic, two will give me a good start to test my idea.
This will become the basis of a fan leaf folding mechanism, if my imagination proves to be correct !
John
I have enough problems just designing a square, so I’m definitely no help. Have you tried something like Tinkercad to design it? I can’t quite picture the grooved semicircles in cross section. Will be very interested to see what your design is though. Just sorry I can’t help.
Thanks, Ellen, for your reply. At 87, I’m now trying to teach myself Blender, so please wish me luck !
I’m OK with Inkscape, but having found a commercial outfit fairly close that might quote for the cones, I realized that a proper 3D file might be needed, hence Blender. If that makes it possible for you, please let me know.
Thinking that I might add a 3d printer to the Pro, I have been considering setting myself up, but my real need is for the ability to print small ‘bas-relief’ inserts for my fan sticks, say 40mm x 15mm x 1mm, and that looks like a resin printer, a whole new ball game for me.
John
PS will look at tinkercad.
I’ll make it for you. I’ll shoot you a design in a little bit.
OK John,
You can look at the model here. Just “view in browser” if it asks. I’ve made it so you can download a file if you want or I’m happy to print for you too.
Edit: Do you want any chamfers or filets on the ends?
Cheers!
For anybody that doesn’t want to look at the link
Either we’re both right or we’re both wrong because your model looks the way I imagined it.
That’s spot on ! Looks amazing. No, I don’t need any chamfers. I shall be adding gears to each end, cut on the Pro, and they will be aligned using the steel rods that drop into two of the grooves.
As the two cones turn, each rod will press the paper leaf into the empty groove in the opposite cone, alternately, so there will be a ‘fold’ line, up and down, to assist in the folding of the final leaf.
This has been in my mind for several years to do, and the request from two ‘wanabee’ fanmakers in UK, got me thinking that it would greatly assist them, if they had such a device. I’ve been trying to make it using just the GF, making molds and casting in PU resin, and after the last iteration, possibly the 12th, it dawned on me to get it 3d printed.
I’ve also now found a description(but no pictures) of the same idea in a book of French patents of the 19th century, so nothing new there then !
Regards,
John
PS adding my own gears later gives me the opportunity to change the separation between the cones to allow for different thicknesses of paper. The surface will probably also have a foam rubber cover to assist grip, and prevent slippage.
It only took a couple of minutes to model. If I hadn’t been sitting in another room I’d have just modelled it the first time I commented.
Now I´m intrigued. Please do show your creation when it is finished @johnbrooker
Happy to spread the idea. It will be free to use, just in case we have more potential fan makers out there !
John
Fan fans?
:innocent:
Sorry, that was old when Noah was a lad ! :upside_down_face:
Fans are something I’m interested in. Makerworld has some litho fans that are cool. I just haven’t gotten around trying them yet!
Just searched for your reference to lithofans at Makerworld. Thanks for that - yes, pretty cool.
Got a different idea though. Litho to me means a form of paper printing, ( worked as a “litho chaser” in a book printing company for a while) rather than lithophane !
Only see the one illustration. Are there others ?
Regards
John
Latest mad idea
It would be a great advantage to me if I could reproduce small quantities of decorative moldings of my own design, or antique sources of designs, that would fit into a space up to 2" in length, 0.5" in width, and with a maximum height of ~1/32". Think small lace motifs, but reproduced in resin, which would be inlayed in 1/32"thick wooden sticks.
The sticks I can successfully cut on the GF, but using it to engrave a small pierced bas-relief doesn’t work because of the grain weaknesses at this scale.
Even just producing ‘one-offs’ which I would then cast in pu resin in silicone rubber molds for short runs would be good.
I am currently thinking of a diy msla resin printer, as I have some experience of cnc builds of my own, and have plenty of ‘bits’ lying around, from aluminum extrusions to Arduinos. Just a uv source and a suitable mask screen might get me going.
Any other processes that I might look at ?
John
I mean if you’re on a strict budget sure but resin 3d printers are super cheap nowadays. Elegoo’s printers that would probably fit your needs are $200 new… I don’t know how you value your time in this equation but $200 wouldn’t get very far with me.
Elegoo’s printers are pretty much plug and play, you’d probably be up and printing in 30 mins of unboxing. I’m sure the build would be fun on some level but we only have so many hours in the day, right?
(Btw I was referring to the elegoo mars 4 9k)
Heck a preowned mars 5 on Elegoo’s site is only $117, shipped.
Thanks for that heads up. Just purchased the Elgoo Mars 5 :upside_down_face:
Kind regards,
John
Use this link Lithophane Maker , you can upload your own pics and make a globe, lamp, etc. works great. I made a couple of lithoplanes on the GF a few years ago.
This is where I’m going - the idea is to cut the outer frames with the GF in wood veneer, possibly epoxy reinforced, and inlay the decorative elements using the sla printer.
It might be interesting to see if the motifs could be printed directly into openings in the wood ! :upside_down_face:
These originals are on the first fan I ever bought, and was the stimulus that made me become a fanmaker. Original created by Poggi, a fan painter in London in ~1764.
I started working on a fan design a couple years ago for the GF. I had it where you could glue paper to the spines, but it was so thick I just threw it away, mainly because I didn’t have thin enough material.
I love fans, and have one I have from a friend who passed away. I’d love to carry it around to use (hot, humid Southern summers), but I know it would get destroyed in my purse. So having something I could print over and over would be great.
