I moved your post over to Beyond the Manual because you’re discussing non-PG settings.
Question - are the posts wood or acrylic? Did you glue the posts to the wood, and then slide the acrylic sheet over them - or no glue whatsoever and you’re depending on a friction fit? I’m missing a step!
Thanks. The posts are wood, but I think I might try acrylic next time.
Just a dab of super glue in the hole in the wood and then I coated it with spray poly a few times. Light sanding in-between each coat.
Then a dab of glue in the holes of the acrylic and press it together.
