Assuming these are for CUT settings…for my basic, they are:
Med Maple Ply 155, Med Draftboard & White Acrylic 168, Black acrylic 150, Med Cherry Hardwood 189, …
So the Pro cuts settings are ~10% higher, but that doesn’t necessarily translate to actual speed, so you can’t extrapolate increase in power…
if the pro is 45w and basic is 40w, and full power is actual full power, it should be about a 12.5% difference at full power.
True, but I’m comparing cut speeds, not power.
They are hideously non-linear. A cut that takes 7 minutes on 100 speed takes 9 seconds at 500.
I expect it’s more. Otherwise there wouldn’t be a power “space” between 100 and Full on the Basic. So if a Basic Full is 40W and 100 is 35 (just for supposition), then the power gap on a Full is also 35W at 100 and 45W at Full or a 10W increase, nearly a third over a Basic 100. The 12.5% delta between the machines should only be seen comparing Basic Full and Pro Full. But that doesn’t help in nailing down how to translate a Basic Full/x-Speed setting to a comparable Pro Full/y-Speed setting because of the non-linear nature of the speeds (seems to be exponential…don’t think it’s a steep enough curve to be logarithmic).
Just wanted to congratulate everyone who took part on this thread. The level of conversation was just fantastic and the conclusion though inconclusive was fascinating. More importantly I realized that my pro is significantly under performing, going off the posted material timings. I contacted GF and after a few conversations support and tests it now needs to go back and be replaced. Perhaps when a fully working pro arrives i’ll be able to join in with the discussion : )
