6.5 lbs of Acrylic - Lake Superior Map (follow up to Lake Erie Map)
Love the different blues, Nice work!
It’s just beautiful with the three shades of blue!
This is by far the best I’ve seen. So do you use a full piece of acrylic for each layer, cutting out the different shapes you want within the lake? Amazing.
Yup! A full piece of acrylic for each layer! Gotta use a full sheet in order to hold it all together. Here’s a side view of a previous map, no glue is used (except on the islands of Lake Superior) :
I was just going to ask that question, is it a full sheet? cannot really tell from the picture are you putting a space between the layers?
seems like a massive consumption of acrylic. I would be tempted to make the layers a 1"band around the dimension and then use something else. surrounding it with a polygon. OTOH, that might simply be more work, and not worth it. I suppose it comes down to selling price ratio to materials/time/labor cost. :slight_smile:
Looks AWESOME
A plastic washer between each layer for more dimension.
Yes, it is an acrylic eater with each layer being a full layer but I worry about the integrity/longevity of the structure trying to hodpodging each layer together.
And in truth- from my acrylic source - each layer of acrylic was cheaper than each layer of maple. Sooo🤷
Plus: that visual from the side!
What are the dimensions. And I agree about the integrity.
18.5" x 10.5" x just shy of 2" so as big as glowforge plus would go!
Wow ~ cool to see your progression in talent, between the two versions. Awesome!
Thank you!
Nice rendition of gichi-gami !!
You calling it gitchi-gami reminds me of one of the very first Glowforge projects I did… I had forgotten about this one…
The 3 different colors of acrylic turned out great. Nice gradient.
That makes total sense.
as to the edge, I’d have just put a wood border around the edge.
i’d be worried it would fall off the dang wall.
I tell people it’s a table/shelf piece :slight_smile: it’s thick enough that it stands on it’s own.
That’s so awesome! I’ve been wanting to do one for Grand Lake here in Colorado but I keep having trouble editing down files. I just need more time I think!
This is lovely! I’ve been making a lot of lake maps myself! Great work!
Do you have any issues with alignment on edges? Are you gluing these pieces together along with the bookbinding hardware?
Here is one I did recently
This is fantastic. I have wanted to make one of Table Rock Lake here in Missouri but haven’t found a good map file yet.
The only glue used was for the islands!
As for the lining up - that’s all done during file set up. Since I work in Layers in Illustrator, when I need to save a layer for the Glowforge, I just turn off the other layers. So the Chicago Screws layer? yeah that layer never got turned off so they are in the exact same place on every single file - so they thats my lining up :slight_smile:
Does Missouri provide public data for lakes?
Looks like they have a data portal available
