6: I don't know what settings to use to cut my material
Return to the common questions index
This page has (nearly) everything you need to know about settings.
  • What the settings do
  • Things to know about the Aura/Spark models and acrylic
  • How to test to find ideal cut settings
  • How to find ideal engrave settings
  • Glowforge’s settings FAQ
  • Suggested settings for various materials
What the settings do:
Things to know about the Aura/Spark models and acrylic:
How to test to find ideal cut settings:
With engraving, there is often no one “right” answer. There are several variables when it comes to engraving[1], what will look good to you is up to personal preference, and that may even change depending on your artwork and material choices. After a few engraves you’ll have a sense of what settings work for you.
If you want to test engraving settings, several grid templates have been posted. Here is a search link to get you started:
https://community.glowforge.com/search?q=Engraving%20test%20template%20in%3Afirst
The Support pages have an faq that covers a few topics, including how to see the numbers behind proofgrade settings. Here’s the link:
The community has gathered lists of materials and suggested setting estimates. This can be helpful, but testing is more accurate in the long run.
For the Basic/Plus/Pro::
For the Aura/Spark :
There’s also this third party aura settings list:
These settings are unofficial but may be helpful.
  1. These variables include
    Speed
    Power
    Lines per inch
    Number of passes
    Focus height
    Convert to dots/convert to pattern & pattern density [for raster engraves only]
    vary power & minimum power [for raster engraves only] ↩︎
