Another attempt of mine to create a multilayer animal. I was hesitant about the balance, but after 1 try I found the correct hole placement for the stand.
I was worried about the weight on the stand/branch as well, but there was no problem with that either. This wood is very light.
Wood used is 1/4" walnut and mahogany veneer.
I do plan on making others, but please let me know what you thinks of this one.
The only change I would do to my own plan if I bought it, would be to make a duplicate tree/owl shape and place it one or two positions behind the top piece. Gravity is always going to win, it just doesn’t have to be too soon. If you do a couple dry runs before gluing in place, you can find the one that creates the best visual effect.
Your work is stunning; thank you for showing it here.
I was thinking about that, but on my previous creation I accidentally created an extra outline and put in front (with my wife’s suggestion). It looked way better, so that why I made the stand part of the front layer.
This could of course be changed to the middle layer for a bit more stability, but it was such a joy to create.
