This one is interesting, when you guess a word it tells you how close the letter in each spot is to the correct letter physically on the keyboard. You can change the color scheme but I use the one called stoplight.
So for instance if you were to guess a letter in the first spot that comes back as bright red that’s indication that you’re really far away from the correct letter. If it’s a bright green then you’re very close to the correct letter, and if it’s white it’s the right letter in the right spot. Here’s my result from today:
QWERTLE #655 3/6
https://qwertle.friedman.in/
