So I spent a good amount of time coming up with this and figuring out the best way to keep it slim and easy. It’s made of 5 total pieces. Four of which is wood and one acrylic window. The acrylic window free floats with some grove inlays in the design and the wood is glued together. Every piece is different even though they look the same when together. Back piece is solid, second last has an engrave line for the lights to go through, next layer has the grove slots I talked about and that same layer the window floats in the groves, and then the top layer has the design. Total thickness with all layers is about an inch.
Here is the back where the power pack sits behind:
Comments are welcomed.
Hopefully I covered most questions for you.
Files for this design can be found here, already a few of you making them on instagram I see: https://www.facebook.com/groups/fscnameyourownpricefiles/
All my creation can be seen here: fb.me/freshstartcustoms or instagram.com/freshstartcustoms (the more popular ones) if interested in seeing them.
