Yes I am. Since I don’t have a form to set them into (yet), I do it by heating the piece while it’s supported by insulators, then spike it with the wooden knitting needle, and use pressure to bend the piece into an organic curve (ie, don’t burn my fingers). Some acrylic is quite compliant, other stuff is ‘good enough.’
Thanks! The smallest one is really too small, but it can be a stand-alone button or decoration for a loosely woven/knitted fabric. I’m using up waste I could not bear to throw away, and the waste. of the waste will become some other project.
At first I did it to reduce snagging potential and then I found out their appearances improved a great deal.
It is time-consuming though. In this particular application, I have to treat it like silver. Everything has to get hot enough before I am able to move an area. But not too hot…and don’t burn yourself. Hot solid acrylic looks just like cold solid acrylic. [Or silver, or glass, or cookware…]
I wonder if you could find shot glasses the right size? Then you could allow it to slump over them organically rather than pushing them into place (get it a little hotter and it’ll start all on its own!)
