Note: if you use the file as-is, it MUST be glued to stay together. I simply pre-assembled it, wrapped a couple rubberbands around it then hit the joints with a bead of CA glue.
I did remove the artwork because… hey, ya’ll need to customize your own!
I did think about it… but then I would have to get more solvent and bottles to fill it, cause I can’t have an empty storage space sitting around here and I can’t throw anything away.
