I shrunk the reindeer size to match the sleigh and allow multiple sleighs and four reindeer to a single sheet of Proofgrade. I won’t repost the reindeer SVG with the size change because those were originally his design, not mine. But feel free to do with the Santa sleigh what you wish. (Oh, and I should mention the red lines in the SVG are score lines. Don’t make the mistake of setting them to cut.) I tend to do a lot of quick simple designs instead of engraves. The sleigh and 2 reindeer take almost no time to process and 5 -1/2 minutes on a pro to cut.
The Santa was kind of boring so I modified it a few months ago. This file was altered for some thicker material that I had. I think the thickness was about 0.188". That means if you decide to use the design below the notches will need to be resized for PG material.
