Got a big tile that has been sitting around for a bit, and finally got it made and set up.
Only one like it anywhere, and it’s yours.
Hoping it causes a rush of neighbors wanting one with their address, but not as yet,
That tile works perfectly for addresses!
Yes, that could be a good small business opportunity.
Love it with the Celtic design. You’ll smile every time you pass by it!
Was my first thought when I saw it.
What is the size of the tile you have used in this very practical creation? Very nicely executed!
12.75" x 4.25" x 0.38" in the thicker parts
What kind of hanger did you use? And how did you affix it?
I heated the tile a bit on the stove and then covered it with hot glue getting a really good bond there and then held it to the final location till it cooled. the extra heat of the tile made the glue stay melted and heat the wall material that was also freshly cleaned and the bond looks pretty good.
for fixing technique as well.
John
Love this! How did you make the text and design gray in color?
That was simple Sharpie rub and wipe. Unfortunately the sun does fade it so it needs to be reapplied.
Well it looks great!
