Hi! So…I recently got adobe illustrator & when I upload designs made there into the GF workspace some of the parts, lines, shapes etc act as different pieces. Example, an image of a face I created just to see how it work when uploaded into the GF workspace separates, a line from the hair, a circle etc upload as their own shapes. Perhaps there is a different way I could save/upload the images?
the GF user interface separates actions by color. so if you have one hair that is 151/152/175 in RGB, and another that is 151/152/176, they will show up as separate actions.
when you set up a file to cut/engrave/score, you want to use a single color for each action. so, for example, if you had a score, a cut, and an engrave, you could set up:
score: 0/76/151 (which is a blue)
cut: 66/151/181 (which is a red)
engrave: 0/0/0 (which is black)
that would give you one setting for each type of action.
if you wanted to engrave two different parts differently, you could do:
engrave 01: 0/0/0 (which is black)
engrave 02: 255/130/0 (which is orange)
and then set different engraving settings for the black and the orange.
