15 passes at this setting only got about quarter way down through the .44” Rosewood
Same with 300 speed
Same with 300 speed
Try this but with .44 for hight.
I tried 125 speed and 60 pwr, 2 passes on top and another 2 passes on bottom. Managed to get it perfectly registered. Did another 3 passes on bottom at 300 speed and 60pwr (2 passes total on top, 5 passes total on bottom)
The board is still one piece and pretty solid. But when I bend it I can hear some faint cracking noises and see it flexing slightly at the weak spot. It doesn’t bend easily by hand, takes a lot of effort with my two hands. But balancing the board with the cutline directly on a stair railing and pushing on both ends, I can see it bend more at the weak spot and hear more of the cracking noises coming from there
Do I dare crack it?? Or should I get out the saw and do this the right way. ![]()
The double line was to compensate for the width of my saw. ![]()
By the way. My method of registration was awesome. I plastered paper over my crumbtray honeycomb surface. Then I did a 500/1 cut of all the cutting lines onto the paper. Then I had myself a guide for the rosewood board: just lay it on top the cut lines drawn on the paper. After the job finished, it was very simple to flip the rosewood over and line up again.
Basically i ignored the imperfect camera. I left the art in the app and hit print again and again. This guide Was especially important because I needed the full 3” width of this board. So I didn’t want to be off.
Decided to do some archeology:
On the end I had a hair line cut to square up the piece… I used an exacto blade and cracked off pieces so that we could see just how deep the laser went:
Is that Rosewood a flooring plank?
I ask because there’s something about the finish and your troubles cutting it, that is screaming “This is a flooring plank” at me.
I had an even harder time cutting a piece of bamboo that was a flooring sample. 12 passes at high power and low speed barely touched it, although it did engrave wonderfully.
Turns out solid woods turned into flooring are often highly compressed and impregnated with tough resins, to make them even harder than normal for heavy use on floors.
It’s from here:
Bolivian Rosewood fretboard blank
http://www.bellforestproducts.com/fretboard-blanks/
Ah OK. Looks like regular solid wood then, tough stuff!
That site has a wonderful selection!
This thread is a fascinating read. Thanks for sharing! Love the wood source link. I haven’t looked to see if The Matrix has a set of materials source links, but that would be helpful.
I have a 1/4" thick board that was made by gluing strips of oak, maple, walnut, and purpleheart wood.
My father had made many similar boards for making hinged boxes. I have the last of his stock.
I wanted to make something from one of the boards with my glowforge. Can you offer any guidance on how to determine the best speed and power to cur through this material with the different properties?
Do you have a pro? I’d start with a small piece of 1/4” oak and try cutting through that with full power and 250 speed. Then go from there. You might do several passes. Test pieces are the best way to go
This probably got lost in the pictures above, so I’ll repost it ![]()
The board is still one piece and pretty solid. But when I bend it I can hear some faint cracking noises and see it flexing slightly at the cuts. It doesn’t bend easily by hand, takes a lot of effort with my two hands. But balancing the board with the cutline directly on a stair railing and pushing on both ends, I can see it bend more at the weak spot and hear more of the cracking noises coming from there
So, considering that side view showing the laser going only 1/4 way down… Not sure that cracking this piece along the cuts would result in a clean enough crack. Imagining pits that you can’t sand out…
Yes, I have a pro. Took three passes and 10% slower speed until the part dropped out.
Thanks. I will have to resaw some purple heartwood and plane to 0.25" and test before
I try the glued up panel. Purple heart wood can have large mineral inclusions.
Purple Heart is dark but maybe the plywood X-ray technique would work at 0.25” to let you spot any inclusions?
Edit- fixed link:
