Yes. 100%. You will be able to make your own custom settings.
@spike, thanks for the quick response! Where can I learn more details about how that custom setting process works?
I donât believe a lot of details are out there about the saving and assigning of custom settings (as in a how to do it, what the UI looks like, user manual entry, etc.).
Dan references it in a few posts: Custom settings for bacon, etc.
We have zero insight into how the S/W is set up. The community has been told that we can save our on presets but that is about it. Still waiting for someone to get their hands on the S/W or interfaces. This following is about as close to an official answer as we have: [quote=âdan, post:4, topic:710, full:trueâ]
There probably wonât be any presets, because the variation between e.g. two similar looking sheets of plywood can be infinite. Like, one sheet will be really quick, and the other impossible, and many values in between.
You will be able to create your own presets, and weâll have performance characteristics for materials we sell.
[/quote]
Just as @gdmccormack and @rpegg said.
Right now, only in-house and testers has access to this.
The testers are under NDA so can not openly talk about it.
Maybe this might change down the road and info will start filtering to the members.
Spike. You may be aware of folks with Beta machines. There is no way for me to know. So far, I have not seen anything from the company or even from the community that hints the program has started other than the plan was to begin the Beta program by this time. That doesnât mean you arenât correct. You may even have less than public info. Hoping that someone at a Seattle makerspace will let us know they have seen one.
All I am am saying is, the people that âDOâ know the answer, can not talk about it right now.
Nothing moreâŚ
But as you already pointed out, @dan already talked about presets in a open forum, so that info is already out there.
Understood. We all are stuck in a circular logic situation. Itâs a Schrodingerâs Cat problem. The Beta units exist and donât exist at the same time.
You got it! ![]()
Lol if I were a betting manâŚ
Heh heh. I drew that conclusion a while ago.
Heh. I thought the first rule of Forge Club is that there is no Forge Club. Like I said before. This âI am not going to talk about it but talk about itâ is annoying. At this point itâs kind of obvious (and has been for a while). If it the rules where not to talk about it or insinuate it- Fail boat for sure.
As everyone is closely watching Spike. Complaining about what he says or does not sayâŚ
The Beta team keeps plugging away in the other room and no one has a clueâŚ
The drama buildsâŚ
Will they find the next bug in timeâŚ
Will the GF crash?..
We will be right back to âAs the GlowForge Burnsâ after these quick messages from our sponsorsâŚ
Does anyone know about suede, something like this: http://www.tandyleather.com/en/product/suede-remnants-12-oz-340-g ? Is it typically veg tanned? Will it cut well on the Forge?
Suede is the âmeatâ side of the leather. So it can come from any tanning process. It is normally thin, but that depends on how the leather was split and how thick the leather was to begin with. Lots of variables on how well it will cut. As that particular listing is for remnants it could wind up being a mix of all types.
There seems to be a Tandy outlet near everyone so if there is one by you, you can stop in and talk to the staff to see what they have on hand. As has been mentioned elsewhere, some stores are smallish retail outlets and others are larger. The one thing I find attractive about specialty stores, even if they are chains, is that the staff is usually knowledgeable. As opposed to big box stores and the thousand yard stare of their teenage shelf-stockers.
Thanks for the info! My nearest Tandy is about an hour and a half away, so I might take a road trip some day. Maybe a phone call would be a better idea at first.
Sorry to keep raising this, but does anyone on this forum have a picture that shows what âdoesnât cut wellâ looks like? I get (and see with pictures) what laser-cutting veg tanned un-dyed leather looks like, but thatâs only a portion of the available leather out there, and maybe some of that other leather out there cuts âOKâ, or âgood enoughâ - whatever that means.
For example, letâs say a particular type of leather tends to curl or shrink a bit during cutting. How about sandwiching the leather between two layer of sacrificial material such as cardboard, to hold the leather flat during cutting.
If we understood what goes wrong with less optimal leathers, perhaps we can discuss ways to compensate. Then we can explore more materials and gain greater value from our Glowforges, thereby making the product even more popular. Win-win.
Iâll post a photo when I get back to the house
@gdmccormack here is a large roll of oiled leather. its pretty thick and fairly soft for its thickness, but the dye will still rub off on you or your clothes if you arent careful. I doubt this would cut very consistently. Ive never tried it before in a laser cutter, but this is the type of leather dan specifically mentioned:
Thank you @takitus for posting photos!
I should clarify that I would like to see the end result when someone tries cutting that leather with a laser system similar to what the GF will use - Iâm talking about the (grisly?) aftermath. Surely someone at GF (perhaps the new guy @madebynick?) has tried leather similar to what you show, and taken a photo of what I think was called a âcooked messâ by @dan.
I can tell thereâs lots of makers on these forums, so I wouldnât expect all of us to stick with just the leather GF plans to source.
