Thank you!! Nice to know…
I haven’t but you can. You will need to punch out the text from stripes that are engraved to have test that isn’t.
Thanks again Marmak3261! I wish my GF gets here already! Sigh
Thank you Brother
Thank you for this information. Seems I learn something new every day thanks to all the knowledgeable people here.
QUESTION - I thought I followed your instructions correctly but my results were off a bit. The stars aren’t spaced correctly.
Your shift X per column reads 27%. You need a higher value. I have 97%. Try that.
That worked! Thank you. It was hard to read the numbers you had as the image was slightly blurred. Didn’t have the correct number of stars with the 9 x 5 so I changed that to 9 x 6, then deleted the last four stars and it came out perfect. THANK YOU!
