Blade is 1/16” hickory clad with raw cherry veneer, a homemade thin plywood. If you look along the blade edge where I “sharpened” it you can see the hickory and Cherry border. It’s subtle but I like it.
The handle is 1/8” black walnut with an inlaid padauk flower. Overall length 7.5”. It was important to me that it feels nice in the hand so I rough-shaped the handle with a Dremel and then finished sanding the curved edge by hand up to 600 grit.
I haven’t had bread & butter in years, but now I just have to go make myself a butter knife.
Thanks for calling out the ‘ply’ of the blade–I went back to the first photo and could then make out the transition from one wood to the other. Very nice touch. And that inlay! It looks like an exotic heat source specially designed to make the butter fly.
I thought about making it higher contrast, I have all kinds of veneers and hardwoods…. But since it’s designed to be in my food I figured it’s best to keep it simpler so I can tell if it’s clean. I suspect I’ll be making some more as gifts this year; I might go a little bolder on those just to make an entrance.
If you look carefully at the side of the handle you can see the layers there, too. Veneers are thin (usually around 1/42") so you have to squint a bit. A much bolder version of this effect was with 1/8" and 1/16" woods in the handle of one of my sword projects:
Absolutely love it, thanks for the nod Love the inlay and the ply… my shipment from ocooch came in the other day, so I’m going to have to make a new batch.
Ah, someone noticed! I intentionally cut all the petals in the same grain orientation to get that effect. The chatoyancy of padauk makes the petals “shine” sequentially as you turn the handle in the light.
It’s the little things, I guess. I did that just for me, but it’s nice that you caught it
Looks great. But I have questions. How well are they sealed? How well do they clean? How do you make sure it is “food grade”? Dishwasher safe? Is taste affected? Will I get a sliver in my tongue from my toast? Inquiring minds want to know.
3 coats of satin polyurethane. I applied it by submerging the entire piece for a few seconds, then wiping off excess. So I’d say “pretty well”.
We’re gonna find out!
The googles said that polyurethane and titebond III are both food safe when fully cured.
I’m a trusting sort, so I went with it. I almost sealed with mineral oil, but decided I didn’t want the maintenance of an oil finish, nor do I like the feel of them for things like salad tongs… so it was poly city.
Dishwasher safe?
If you put this little beauty in a dishwasher, you get what you deserve.
Is taste affected?
Dunno, it’s not fully cured yet!
I suppose it depends on how aggressively you lick your butter knife and how rough your tongue is… are you a feral cat or perhaps a penguin?
… Inquiring minds want to know.
Welcome to the forum @cokley1941.
As you have discovered, this is an active community where we share our creations to inspire each other.
We look forward to see what you you create!
