Thanks to @Jules and @evansd2 for the help with the lid on this box! I wish I had taken Jules’ suggestion to score outside the letters, but I’m still pretty happy with how it came out.
It holds two games that were formerly in much bigger boxes. The complicated pattern on the top took 1.5 hours (mostly scoring all the background detail), and the rules on the inside of the lid had to be done in three passes because of all the detail, each pass taking 10-15 minutes. The base and interior dividers are made of draft board, and the top is maple plywood (all Proofgrade).
Thanks! It’s actually the second box I printed, because I got confused between interior dimensions and exterior dimensions and made the first one 1/4" too narrow to fit the boards. I only made the top once, though.
I think I need to make myself a “Measure once; cut twic” sign like the one my husband put up in his shop. Nothing ever seems to be perfect the first time I press the big glowy button.
There is a little bit of a learning curve. Then you come around the other side, and stuff starts coming out really nice first time consistently, because you’ve done that a number of times before. On your way to becoming an expert.
