PDF file set up to cut 70 mask hooks
mask_s_hook.PDF (141.8 KB)
Cool. I like that design! Thank you.
Great design! Thank you for sharing! I am cutting several of these tonight to donate them tomorrow.
that’s great. another good option. thanks.
Thank you. I cut out a sheet of these yesterday. delivering some today and shipping out some to family members.
Thank you
Let me know if you get any feedback on them. I can easily adjust if they need to be longer.
Will do. They look great as it is. If anything, my materials would cause more of an issue. I got the 11x14 sheet of acrylic from HD for like $7 so I had to shrink your design ever so slightly so it would fit. I don’t anticipate them being too aggressive with them. Thanks again for the design!
acrylic is really easy to cut down by hand, especially the thinner stuff. i bought large sheets of the .093 optix from home depot and then cut it down to 10x18 sheets to cut (which does 60 of these at a time in 18:30 at full/200).
to cut down, get a long straight edge, and line up. score with a utility knife, then bend the scored edge over the edge of a flat surface/counter until it snaps. makes it a lot easier to start with bigger sheets, which are usually less expensive per SF.
Thank you for this wonderful design! Starting to print for the medical professionals up here in Rochester, NY. They like your design better then the simple S-hook. Thanks for your help!!
I just sent 100 to NY. Thank you!!
