Thanks. I’m a big fan of those too. Plus they add a ton of stability to the structure when all is said and done.
Beautiful sign and the wiring for lights is clean and orderly. Nice job.
I have used their extruded rails, bearings, pneumatics, etc for many many projects. Fantastic company. May I ask where to got the lights and block?
The lights and terminal block are from Amazon.
L125W 20pcs Pre Wired 5mm Bright… https://www.amazon.com/dp/B07DWJ7FLH?ref=ppx_pop_mob_ap_share
PCB007 1X 12 Position Power… https://www.amazon.com/dp/B07DW2C4ZB?ref=ppx_pop_mob_ap_share
Thank you, when I get done with my current list of honey-do’s and projects I will be doin’ some playin’
This sign is amazing!
Thanks so much.
Just wondering what your settings were for 3/8 acrylic?
Custom settings can only be discussed in the “Beyond the manual” section, but as 3/8" acrylic is not a Proofgrade material, you will likely need to test with what you actually have. Start with the settings for 1/4" and slow it down or increase power and passes to get an acceptable result.
Note that acrylic is very much prone to flaring up and damaging the machine, so watch it like a hawk with fire suppression handy.
