The show went on pretty well minus the hiccups! great to see you guys in person. wish you had more booth space as you guys were pretty popular today!.
if it runs at 1600 watts peak for an extended period of time⌠and that is done frequentlyâŚon say a 15 amp breaker ,the possibility of repeatedly causing a breaker to run hot will eventually result in breaker to faultier and fail âŚperhaps the GF and the filter might be equipped with separate power in ports so the load may be allowed to be routed to two separate breakers??
Dedicated 20A outlet would be the best. Generally a good idea whatâs on a given breaker.luckily the room Iâm planning to put the gf in will have 3+ 20A circuits (ok, 2 of those likely to feed an outlet or in another room).
Lighting is usually on its own circuit these days (so you are not in the dark if you trip an outlet).
Donât put your latest powerhog of a desktop, laser printer and gf on the same circuitâŚand vacuum at the same time.
Likely just an oversight by someone cleaning up over night, on the other hand heard horror stories back in the day when my dad used to go to one of the big electronics/automation fairs in germany. Lots of stuff getting stolen overnight from competitors if left out.
I have the same problem in my kitchen, we canât use the toaster oven and the microwave at the same time.
A few notes:
- You should be just fine with a dedicated 15A circuit.
- The hair dryer/space heater test is a good one; thatâs worse than a Glowforge because itâs continuous (when printing the laser doesnât usually stay on 100% power for a long time).
- The printer & air filter have separate cords so you can put them on separate outlets.
- You can get a UPS if youâre worried about âbrownoutsâ.
Again, the problem appeared to come from two glowforges and two air filters on one power strip - not just one outlet, the same strip!
Awesome,
Thanks for clearing that up.
Is the air filter completely autonomous or is there a control line connection between it and the Glowforge?
Youâll need a massive UPS to do this. Even the huge APC 1500 has a peak limit of 865 watts. If youâre willing to lay out $700 or so, the CyberPower 2200 will probably work.
Glad to hear it sounds like I wonât be the only one running the glowforge out of a bedroom!
Of course the bedroom is question is literally, well, my bedroom- but hey, quick access for when midnight inspiration strikes!
I have an empty outlet in the corner of my room that will be dedicated purely to the glowforge (no air filter) so I think I should be alright. Other than that I really only have a few lamps and chargers plugged into power strips on other outlets.
Thatâs the ticket!![]()
No kiddingâŚI get some of my best ideas at midnight tooâŚand then promptly forget them by the time morning rolls around, which is muy muy exasperating! ![]()
Exactly!! Iâve taken to keeping a little notebook on my bedstand, but then sometimes when I look through it the next morning after coffee Iâm kind of like âum, I have no idea what this is 3 am chicken scratch is supposed to meanâ
YES!
My usual thought the next morning is âThat was the dumbest idea Iâve ever had!. That will definitely not work.â Itâs the 2% of the time I read it that I think âYes that is an awesome idea!â that makes it worth writing them down.
Oh yes, usually deciphering the scrawl isnât even worth it! Actually, now that Iâm thinking about it, maybe having easy access to a laser at 3 am isnât the best ideaâŚ
I had good company for my journey through the line!
Or a ups for each device it tends that the financially obtainable ups run around 700watts
My office at work has three separate 20A circuits. So I should be good there.
At home my wiring is a mess. Done by a friend of my grandparents in the â50s, itâs not only not up to code now, it wouldnât have been up to code at the time. And as Iâve discovered the hard way whenever I have to venture out to the circuit breaker box, outlets and fixtures are haphazardly connected to different circuits, so one outlet in the living room might be on the same circuit as the laundry room when all the rest are sharing a circuit with the outlets in a bedroom on the other side of the house. Not to mention that nothing anywhere is grounded outside of the kitchen and one bathroom which were remodeled a few years ago.
I think Iâll be keeping my GF at work until I move out of my grandparentsâ house. (Something I was thinking about doing anyway, given my lack of space there.)
It is controlled by the same cloud service as the Glowforge via a local connection to the machine - that is, it gets itâs orders from the cloud relayed via the Glowforge.
Getting the Glowforge on a UPS gets you 90% of the value - youâd have to have much worse powerline problems to bother the air filter. And you could use two UPSs if youâre so inclined, since they have separate power plugs.
So the basic design of both machines includes a switched power connection for the optional filter?
That would be ideal for me, since I didnât order the filter, but need to have a booster fan and could connect the booster there for automatic operation.
Thanks for your time!![]()
