Thank you, everyone, for your suggestions!
The Glowforge Basic has a closed-loop liquid cooling system that uses the air from the room to remove heat. It’s designed for use between 60 degrees Fahrenheit (16 Celsius) and 75°F (24°C) and is perfect for personal home use. If it’s too warm, your Glowforge will pause during the print to cool off, then finish the print. If you plan to use your Glowforge often in warm environments, you may prefer the advanced cooling found in the Glowforge Pro.
