Did you have two separate vectors for the background and the edge of the background? You can’t just have a colored stroke and colored fill on the same object. One object that is a colored stroke for cutting the outline. One object of the same shape but filled no stroke for engrave the background.
Thanks so much for demonstrating this and sharing settings. It looks great!
Good point to bring up, but my previous file of the same set-up worked for the silly BUTTS! test. I use illustrator CONSTANTLY, so if there was a fill on the cut line, i wouldn’t have been able to see the engrave image as the engrave is a raster file and the cut is/was a vector stroke, all together inside one SVG file. I always put the CUTS above the ENGRAVES in the layers palette(screenshots of files below).
There wasn’t even char marks on the back of the linoleum like in the other cutting speed/power tests. There should have been a FEW dots of char on the back. Maybe it just gave up after 45 minutes of operation.
This wouldn’t be the first time a unit randomly quit or stopped during a step(it’s the 2nd time for mine). I know it’s still an early product /shrug, so i’m not upset; I’ll get it on the next go.
Absolutely! There’s not a lot of info on linoleum on here yet, so I hope it helps anyone who might be interested. I’m pretty pleased with the BUTTS! stamp
So way back in PRU-land @Joe and I engraved the inventables (specifically listed as laser safe on the web page). The “random numbers” you see were the old scheme before GF went to random units, one can convert using the spreadsheet.
I wonder if a heat gun on a low setting would get you the right temp? Then put into a press or under some books.
Also I have seen laserable silicon that Johnson Plastic (laserbits) sells. Also a hot stamping company sells a similar laserable product. Wonder if that might actually work better for your Lino prints than Linoleum.
When engraving linoleum with hand tools, it’s recommended to warm it slightly. It’s really mostly a solid form of oil that at room temperature and reasonably high above room temperature is stable and firm. So some variables there in terms of prep.
Linoleum like this is sometimes worked by hand without being attached to a block, but you might consider whether you could get small blocks of it cut and engrave with the crumb tray out, and then use a hand tool to remove the additional material around the part you engraved.
The engrave took 40 minutes on the big “final” stamp, and it left some residue on the fold-down flap. But not a ton. I cleaned it off with isopropyl on a rag and it seems fine. I need to get some more zeiss wipes though and check out the lenses in there.
It smelled like… a super organic, vegan muffin that was very overcooked. Not great, but not terrible.
What is the reason for using linoleum as opposed to other stamp-making materials? Various laser-safe rubbers for stamping have been discussed here before, but linoleum stamps seem like a thing.
Maybe? I had my expectations in the wrong place I guess, because this is decidedly NOT GREAT for making little stamps by hand-pressure alone.
Rampant stupidity on my part. As you’ll see below, I wish I had ordered laserable rubber
Today I’m grumpy because this stuff doesn’t behave anywhere near what I expected.
On a trip to michael’s I found some $2 stamps that I ripped the stamp off, sanded, and glued my “stamp” onto. Also a stamp pad to test it out.
It’s gotta be too much surface area to nicely apply pressure onto the paper
So here’s a test with me standing on the stamp with one foot:
So I’m glad I didn’t waste my inventables gift cert $$ on some lino(not like the real $$ i wasted on this stuff) because what I really want is RUBBER. LASERABLE RUBBER. And all the places I’ve called today do NOT carry it #grumpface
I totally thought this could be used for hand-pressure style stamps. My stupid mistake. It does work for teeny tiny ones at hand pressure though.
Since i have SO MUCH of this(does anyone want some? ;D ) I thouht I’d run another test because it isn’t bad for small stamps. The size is really what seems to be the problem with lino.
Rather than burn through a bunch of the stuff & dirty up everything, I cut out all the places that would have been engraved flat. This stamp is 38 mm by 36 mm.
You may find this posting, where I use art stamp laser polymer, to be of interest:
Although I did buy some laserable rubber from the same source, I still haven’t tried it. I like the relative cleanliness of the laser polymer in the machine. It vaporizes the polymer and ends up not leaving much residue on the stamp (there is some, you can rinse it off with soap and water).
