Working up another Flyfishing-related design. I’ve made fly boxes using my Shaper Origin for a year or so, but they take so l-o-n-g to hog out the centers compared to just cutting with my Glowforge and stacking the layers. Might be onto something here…
I can absolutely see this being made in some exotic wood. Maybe about 10 years ago I was at the used bookstore and I came across this vintage fly fishing book. The book was from the 1940s or 50s and the bookstore only wanted two dollars or three dollars. I purchased it not knowing anything about flyfishing.
The book was about how to make all these different fly fishing lures. If I knew where it was I would take a picture and post it.
Why not use a Forster bit to do the majority of the pocketing? If you stay far enough inset, shaper will still be able to clean everything up.
For this kind of box I have switched to using the shaper to cut out a template of the opening, then a Forster bit to hog out the waste, and finish with a small bowl bit. The bowl bit leaves a nice radius.
If one is stacking like that, then using 3/8" wood to cut 4 pieces with strong rounding at the corners on each layer can make it side grain on all sides. And engraving in the thinner top and bottom would make all the end grain only on the corners plus you can round all edges that way.
I have some of those hinges, and the ones that are just the two pieces and was wondering how I would use them. That is a really great way.
I know. I was going to make a small box to put see’s candies in for v-day. So long, next time I’m thinking of hogging out the bulk with a Forster bit an d us the shaper for the fine work. Or get my shark cnc up and running and use it
