I saw a file on etsy that I liked and the guy had made it too large to be made on a Glowforge. His file was handmade and not done on a computer. I wanted to be able to create that same look on Inkscape just to see if I could. Well it appears I can! The file has changed a bit since I took the pictures but I offered him a copy so he could include it for those with a Glowforge since it was his idea. Since I gave him a copy, I figured I could give the Glowforge community a copy as well. Hope you like it!
I have it set so Black is score, Blue is cut first and red is cut last. Made with 1/8" Baltic Birch. The SVG has the face scored for easy placement of the smaller pieces.
UPDATE: I noticed that in the file the hole was 3". It was supposed to be 2" That has been corrected and the ribbon has been added as a cut piece to glue on. Added drain holes in the bottom. Also added a zip file for the squirrel feeder with the larger 3" hole.
Not sure yet. At the moment I try to keep one of everything I make in case a friend should want one. If I do put it outside, we have a covered patio that would protect it so it wont get much weather.
Nice! Seeing your application gave me a few more ideas for it. I will put holes in the bottom for drainage when it rains and figure out a door that can open to make it easier to put the seeds in, also the ribbon that is scored I can make into another piece to be glued on for decor. Thank you for the ideas! Revision coming soon!
