I used the software from Cartocuts and downloaded this map of my local area, Bellingham, WA. This particular version is only 5"x7.5", so much of the fine detail is lost. I wanted to try this out on draftboard first to see if I’d have the patience for a scaled-up version. (This one took 30 minutes…that’s a lot of Solitaire on the iPad.)
Anyway, I like the small version enough that I’ll make time for a larger engrave. And yes, we really do call ourselves “Bellinghamsters.”
I misread the title as “bird’s eye view of us being hamsters” and expected to see you rolling around in giant balls. I’ve gotta admit I’m a little disappointed, even though the map IS nice and all…
I just finished an updated version of the map. I used an unprimed wood panel as the base; 9" x 12". Since it was 7/8" thick, I took out the crumb tray for this one.
It just keeps getting better! This was a dress rehearsal for the “real map”, which will be a gift to a friend. Even though I had cleaned the surface with 91% alcohol, it had a muddy look to it; probably fumes that had nestled into the pores & fibers of the wood. So, I sanded it, vigorously.
I started with 180grit, always going with the grain. Then I wiped & cleaned w/alcohol. Next was 220 grit, followed by cleaning. Then I wiped all over with a rag impregnated with beeswax and mineral oil.
I’m amazed at the level of detail captured here. It didn’t so much lighten up, as become clear and legible.
I don’t know if i want to know the answer to that question
I’m just using my imagination, think about the suffix used for Colorado.
Now apply that to Tampa.
I don’t really wanna know based on what I imagine it is.
