Greeting from a new forge user! - I am still learning, and getting the hang of it all, my one big issue is ‘layers’ in the glowforge web program, I imported a bunch of lines, and set power to them, but they always hide (ignore is NOT ON) when I do the print / burn, even though I see them in preview
There aren’t really any layers in the Glowforge app…just steps in the job. If you have an engraved area and put lines in the same place, the engraving will obliterate the lines regardless of whether it comes before or after.
An image of your artwork would probably help us be more specific, though!
the three lines, I created in illustrator. (top box)
you can delete a whole ‘storyboard’ but you can’t delete objects in the ‘storyboard’ only set them to ‘ignore’
My guess is that they’re off screen somewhere. Zoom way out and see if they’re way off to the side. A quick way to tell is to zoom out and do “control-A” to select all (command-A on a mac). The resulting selection rectangle will let you easily tell where all your stuff is.
The real solution here is to step back and design the entire card to exactly how you want it in your vector program. Adding elements like this can be a time saver sometimes, but the best way to get it right the first time is to do it all in your source art. Bonus: it’s editable and tweakable and repeatable if you do it in your original art file.
I agree, that’s my next step to do it all in illustrator and make the objects with different burn settings different groups… Just taking the Glowforge app out for a spin.
