My living room isn’t dark per-se, but with my eyesight I often need to use a flashlight during the day to see small things clearly - no direct sun makes it in.
I’v had some of the 50cm acrylic mirror panels for some time but never used them for anything, so this morning I did a test with them, propping up to reflect sunlight in thru my french doors on end end of the room. Lit up great, so…
Made a tripod plate adapter, three simple layers with a bit of fettling on the top layer seen here, which is actually the bottom, and slides onto the head.
The result - 100% natural sunlight, when the sun is out. Takes a second to adjust as the sun moves across the sky. Won’t do me much good in winter as my yard gets very little sunlight for a few months.
A flat reflective surface and a slightly concave one at almost 90 degrees to the plane would put a broad bright area on the north face of the building most of the day even as the sun moved across. If the flat plane was water then the light would ripple in the wind
We have very long eaves, which keeps direct sun off the windows other than sunrise and sunset. When you live in hot area your AC thanks you, however, I feel your pain, the rooms can get rather dark.
Interesting solution. Seems like a lot of work, but you know best.
We solved it by switching to LED lamps, when needed, in the active rooms.
And here I am like a vampire with all my curtains pulled shut. There are some days that my wife comes home where I haven’t opened anything up yet and immediately opens everything up. We’re definitely on different ends of a spectrum
Cool idea, it reminds me of when my phone is on the seat in the car and the sun reflects off of it to blind me
Well that is certainly a unique use for mirrored acrylic. Maybe for your next phase you could do a kinetic sculpture that would move the light to play with your cat(s).
Reminds me of when I used to play with my handmirror shining light around my bedroom in the morning. I’d make circles, ovals, make them go fast or slow, dance into the corners and all manner of magic.
That’s a really nice way to bring the sun into your room.
