Another stadium is complete, this time around it’s Busch Stadium in St. Louis, MO. , seven layers of Proofgrade Maple Plywood (my favorite). Settings were Proofgrade cut, draft score, and SD Engrave, machine is a Glowforge Pro, total cut time of just under 14 minutes.
This stadium is another that is built on a sloping elevation, so the model incorporates a split topography which makes the model 5 layers above ground level (base to top of towers) on one side, and 4 layers above ground level on the other, and a sub-level which places the field below ground level. Like my last model of Dodger Stadium, this one also has feet to elevate that base and provide clearance for the field sub-layer, and I’ve incorporated the use of round toothpicks to aid in positioning layers during assembly, something mentioned by another user in a previous post, which really helps with accurately placing each of the layers during assembly.
I hope you like it. ![]()
