I have been trying to engrave on butcher block but keep getting a material setting error. I have it set to manual focus . I have cleaned all the sensors. The wood is just under 2" thick.
Help would be greatly appreciated
Aunt Patti
Welcome to the forum.
What setting did you put in for manual focus? Have you tried setting focus on the board?
Yes I did but still get the error
Welcome to the community!
It would be helpful if you shared a screenshot that shows the error. “Material Setting” covers a lot of ground…
As suggested, a screen shot showing your setup and settings would help us help you.
At 2" you need to have the crumb tray out…
Also which machine do you have? The aura and spark can’t handle 2” materials.
I did have it out
My guess is the material is too tall.
I have tried engraving thick pieces and “close” can be a hair over and give all sorts of issues, even 15/32 on the tray I managed to do but it was a lot of problems. I think I used a 7/16 piece right next to it for set focus but used the numbers and not the image to set the location.
