I need to recalibrate but I don’t have medium draftboard left, GF is also out of stuck. would a non proofgrade 12x20 MDF work, as I measured the draftboards and they’re 12x20.5
yes. Just make sure it is totally flat. And if you mask it then you can remask the same sheet and use it again if ever needed.
thx u! I just tried this morning with a maple plywood I had on hand, and after going thru the whole process, I got the message they couldn’t recalibrate my machine with this material. do I keep the setting for draftboard or switch it to what I used to run the calibration?
I no longer had a full sheet of material available when I needed to re-calibrate my machine so I found some watercolor paper on hand and used spray adhesive to fix it on to the skeleton of a scrap board and used that. It did a very good job and the testing did not cut the paper.
great Idea! thank you!
