Hello, I just got my GlowForge pro and I am loving it so far! I got mine two days ago, and I was wondering since its new, do I need to perform a camera calibration on the machine? Or it should be calibrated already? Ive done a lot of engraving and tests and they seem to be accurate in terms of placement but if I need to calibrate my camera then I will do so.
Many of us had issues with material placement, especially at the edges. This meant you had potential for a lot of wasted material, especially nearer the edges of the bed.
Hey, gilbertslettering is my instagram handle. I am a calligrapher and lettering artist and I bought my glowforge to make wood cutouts of my own lettering to make custom signs, caketoppers, backdrops and such.
It’s definitely not mandatory - but “within spec” for the factory is within 1/4" and the camera calibration got many of us to within a mm - so it might be worth it
As a calligrapher this might be of interest to you: Engraved Cutwork Scroll
(I still haven’t calligraphed it, waiting for someone who wants something from that period!)
Just to reiterate what has been said, if you’re happy with the calibration use it. If you think it can be improved go through the calibration process. If by chance it comes out being worse, email support and they can reload your original calibration file. I recall this happening once, maybe twice, when they first released calibration. They have probably fixed bugs since then.
As I recall it being explained, at the factory they calibrate the glowforge on a very flat and large rock. I’ve seen similar chunks of stone in labs for similar purposes. When we all unbox our glowforges we set them on not quite as flat surfaces and introduce tiny twists to the case. The calibration routine attempts to correct for these.
thank you! i ended up recalibrating my camera and its MUCHHHH better! my projects arent perfectly aligned but its close enough to where you wont notice it. thank you for the info
